Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
No auto-route solution was found.
5 REPLIES 5
pe_simon
243 Views, 5 Replies
I created a 45 degree elbow, when I draw a pipe and go up to 45 degree, the 45 degree elbow connected error.. How to fix it? Thanks. I added the file for study.
5 REPLIES 5
iainsavage
in reply to: pe_simon
I changed the primary connector and the family sort of works but maybe not 100%.
fabiosato
In the previous versions, for elbows, the primary connector must point to the horizontal left and the secondary to the right upper quadrant.
This is the way I create all of my elbows, I am not sure if your elbow will work properly, but I never tried something different, maybe it works in newer versions.
Fábio Sato
pe_simon
in reply to: fabiosato
Hi, I re-created the primary connector point to the horizontal left and the secondary to the right upper quadrant.
But doesn't know why also couldn't auto connect.. attached new file for reference. Thanks. (Revit 2020)
pe_simon
Hi, I created new pipe connector it works, but it's not complete connected have a gap? And the pipe are not straight.
fabiosato
I suggest you to check this family provided by Autodesk.
It has the necessary components to make it work properly.
Fábio Sato
