I want to show my duct hood mitered, because I am taking sections to create details from whats modeled. Is there a way to miter an open end of ducting in revit? or, how can I create a family for a length of duct that is mitered in order to use a part to represent the duct? If I have to create a family, the length is 2 foot, but, depth and width needs to be dependent on the size of duct its connected to. I have attached the family I began working on and also a picture of an old CAD detail to show what I am talking about.
Solved by craigjonnson. Go to Solution.
Solved by HVAC-Novice. Go to Solution.
If you want functional airflow, you need an airterminal and not just an "open" duct. Create or edit an existing air terminal to look the way you want.
You have 2 options for your Revit category, Duct fitting or Air Terminal as explained by HVAC-Novice.
Check out the changes I have added, When i started getting into family content i learned a lot from editing existing content and seeing how others had built things.
