I would like to know how do I get the text information to use in the lookup table?
Sorry for my English!! 🙂
Solved by L.Maas. Go to Solution.
Text isn’t a valid unit.
A text parameter would be unitless so I think you just want the column heading to be CODIGO##other##
To get the correct code you also need to use a parameter with a unique value, or a unique combination of several parameters, as the search term. In your screenshot the value of C is the same in every row, so what is different about each type to point towards the appropriate code?
Screenshot with an example
Note the nn##OTHER## and not nn##OTHER##TEXT
Louis
Please mention Revit version, especially when uploading Revit files.
