So I like to show the furniture on the RCP and the only way I have found to do this is to create a separate view that shows only the furniture and put it on the same sheet as the RCP in the exact same spot. Only problem now is the light fixtures, which I want to show up on top of everything and bold, are underneath the furniture layers and its causing display issues. All of the architectural stuff (including furniture) is the architects model and linked in. Arch link is set to underlay and halftone. Light fixtures are in my model. Any idea how to get the light fixtures on top of the background?
Solved by RobDraw. Go to Solution.
The order that you place the views on the sheet determines the hierarchy. Place the furniture plan first.
@s.borello i wish it were that simple but it never works out that way. The furniture is all a different heights and the building has all sorts of different levels and auditoriums etc.
