Having an issue where either the strut will move or the pipe will move in relation to the global parameter is being assigned to the dimension. If I want 7" off the center of the pipe then it will move the entire strut off center from the pipe or vice versa manually changing the dimensions without the global parameters. Has anyone else had issues with hangers? Specifically unistrut hangers?
