Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Drive Family type selection
2 REPLIES 2
revitworkbench
267 Views, 2 Replies
Ok so I know the work around by using family type selections to drive nested family visibility, but is there a way to Drive a family type paramter  in a host family via other host family parameters? I am sure if it is possible, then my only mistake is in syntax. So please be as specific as possible thanks!
2 REPLIES 2
L.Maas
in reply to: revitworkbench
Can you be more specific about what you want exactly (example)?
If in you host you have a family parameter for length and width than  you can create a formula to drive the other parameter like in the formula section of the length parameter you can write "=width * 2"
In this case the length parameter is driven by the width parameter.
But I imagine you have something else in your mind.....
Louis
Please mention Revit version, especially when uploading Revit files.
CoreyDaun
Take a look at this previous thread: Dimensional Parameter driven by "Family Type" Drop-down Parameter
My post #2 describes the method of creating a parameter that is DRIVEN BY a <Family Type...> Parameter.
My post #8 describes the method of creating a parameter that is DRIVING a <Family Type...> Parameter.
These methods are fundamentally the same.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
