Show only
Search instead for
It would be A BLESS to be able to create a subcategory in user material libraries.
For example, I can have a Category of "Metals" and then "Iron, Steel & Aluminium" as subcategories! This will help with keeping a clean and neat material library!
@Anonymous Absolutely. At this point I am creating a material library and since we work with a lot of manufacturers, we already have their prices. Therefore, it would be so much easier to clasify information and simply pull what you need!
Ability to assign color separately from material. Material should stay the same and modify the color/finish of the material independent from the material as to not clog up the project materials with duplicates for different colors. Also would allow phasing of the colors without modifying the parent material asset to allow colors/finishes to be applied in different phases.
