Revit Architecture
Active Member
0 Kudos
Post 1 of 5
Zoom Sheet Size
522 Views, 4 Replies
08-14-2012 01:22 AM
There isn't a lot of information out there on this zoom tool.... so...
I thought this feature would zoom the view to 100% of screen size. Effectively, I could measure off the screen with my ruler, becuase it is zooming to sheet size, which is to scale.
This is not the case, and I cant figure out what scale it is zooming too.
Could someone help me with this? Not sure if it's a bug or not.
Thanks.
997 Kudos
Post 2 of 5
Re: Zoom Sheet Size
08-14-2012 07:50 AM in reply to: mclothier
This is what the command seems to be trying to do, as the zoom changes based upon the scale of the View.
It doesn't get it quite right - seems similar to trying to measure from a PDF off of the screen at actual size.
Product Support
41 Kudos
Post 3 of 5
Re: Zoom Sheet Size
08-16-2012 01:51 PM in reply to: CADastrophe
I found another thread that has info on this topic:
How do I change the sheet size for the Zoom to Sheet Size command (ZS)
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/How-do-I-change-the-sheet-size-for-the-Zoo...
Lance Coffey
Active Member
0 Kudos
Post 4 of 5
Re: Zoom Sheet Size
08-16-2012 04:06 PM in reply to: mclothier
I've tried it out, but it doesnt actually zoom to sheet size as the command suggests. It zooms to about 75% of the sheet size. (Regardless of which title blocks are used)
Am I doing something wrong here?
Product Support
41 Kudos
Post 5 of 5
Re: Zoom Sheet Size
09-06-2012 11:15 AM in reply to: mclothier
It looks like the size of the model on the screen (when using the zoom sheet size command) is related to the resolution of your monitor.
Lance Coffey
