You want to tie it into the Visible parameter. Open your family and select
your object, then click on the Properties dialog box or right click and
select Properties. You should see a option for Visible, there's a button
next to it that you can click, not the check box but the button. Select it,
give it a parameter name. Then go into your Family Types and you can set if
you want it on or off.
wrote in message news:5532873@discussion.autodesk.com...
I want to be able to turn off the Sills and architrave of my windows if i
want a square set sill. How do i do it? Is it through the yes/no type
parameter? If so how do i tie the Architrave sweeps to it?
Nathalie
