Revit Architecture
Active Member
0 Kudos
Post 1 of 3
Wrap base at end wall
307 Views, 2 Replies
12-12-2013 07:41 PM
I added base to wall in sweep and I change to interior or exterior in Wrapping at Ends. It does not show any base at end wall. Did I miss anything? How I can make it work?
Richard
Try this:
  1. In a 3d view click on  sweep profile and then from Modify / Walls > Wall Sweep > Modify Returns > click once on the end of the sweep (Angle to be 90 degrees or any angle you want)- the sweep will turn perpendicular to the wall art wall's end
  2. using TAB click on the face of the section profile and drag it to the desired position. You can use Align in order to align the end of the sweep to the otehr face of the wall
331 Kudos
Post 2 of 3
Re: Wrap base at end wall
12-13-2013 12:33 AM in reply to: rsabclin
Try this:
Constantin Stroescu
BIM Manager AGD
Active Member
0 Kudos
Post 3 of 3
12-13-2013 06:54 AM in reply to: constantin.stroescu
It works! I guess that it won't automaticlly apply to all walls and I have to do it one by one at end walls. Thanks.
