Hi there,
I accidentally pick the detach &discard worksets option when i want to detach my file from central file.
1. Can I get back the worksets from central file?
2. How do I link back my local file to central file?
3. Do i have to set the worksets manually and reassigned my model to its respective workset again?
Thank you.
@Anonymous wrote:Hi there,
Just create a new local file to get the worksets back.2. How do I link back my local file to central file?
You shouldn't. Create a new file.
As point 1.
Thank you.
Thanks for the reply.
If i've created a new local file, the model would be outdated because i done some adjustment in the previous file. so this means i need to copy and paste the adjusted model in the new local file. is that correct? After i paste the model do i need to reassigned it to the respective workset or will it be automatically assigned?
