Dear All Guru
My team is use Revit building suite 2014 and Revit architect2014
We create workset and central file by Revit building 2014 and when Revit architect 2014 try to create a new local file. The program cannot create a new local file (bottom is in grey and cannot click for select)
In the same way i try to cross for test by create with Revit architect first, the final is same they can't create a new local file too.
Have anyone know how to fix it or i miss in something.
Chaiwat
BILLION THANKS
I'm not sure how you are testing but make sure you have different user names in each session of Revit and that you file pathing is correct. I verified that it works in both directions and I also asked development, they informed me that this was tested fully prior to release and my testing proves this out.
Thanks for posting,
