I need to snap witness lines to the core face (face of stud) and not the center of the wall or the face of sheet rock. Can this be done?
Marc
Solved by loboarch. Go to Solution.
Yes the control I mentioned in the previous post does this exact thing.
This of course assumes the wall you have created defines the "core" the way you are expecting to dimension.
It was not clear you were taking about TEMPORARY dimensions. You can do this with a setting. On the manage tab under additional settings cnage the setting for the temporary dimension preferences.
