Revit Architecture
Distinguished Contributor
marc5
Message 1 of 7 (294 Views)
Witness Line Snap
294 Views, 6 Replies
02-21-2014 07:34 AM
I need to snap witness lines to the core face (face of stud) and not the center of the wall or the face of sheet rock. Can this be done?
Marc
It was not clear you were taking about TEMPORARY dimensions.  You can do this with a setting.   On the manage tab under additional settings cnage the setting for the temporary dimension preferences.
Employee
loboarch
Message 2 of 7 (290 Views)
Re: Witness Line Snap
02-21-2014 07:43 AM in reply to: marc5
When placing dimensions you can set a snap preference for core faces on the options bar pulldown list. You can also use "tab" when placing to pick different selection candidates near the cursor. Depending on zoom this might get the face of the core of the wall.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
marc5
Message 3 of 7 (276 Views)
02-21-2014 08:32 AM in reply to: loboarch
Thanks for the help, but I can snap dims to what I want, but I cannot snap witness lines to the face of a stud. It snaps to center line of the wall and face of material of the wall and in my case that is face of sheet rock. Is there a setting so witness lines will snap to a core face?
Employee
loboarch
Message 4 of 7 (268 Views)
02-21-2014 08:46 AM in reply to: marc5
Yes the control I mentioned in the previous post does this exact thing.
This of course assumes the wall you have created defines the "core" the way you are expecting to dimension.
Jeff Hanson
marc5
Message 5 of 7 (249 Views)
02-21-2014 09:08 AM in reply to: loboarch
Call me a new-b and again thanks, but dims are working just fine and snapping to core face after I changed setting to "Face of Core" as you show above. However, witness lines (if this is the correct term) or temporary dims when I click on a wall this is what I wished would snap to core face.
Employee
loboarch
Message 6 of 7 (233 Views)
02-21-2014 09:49 AM in reply to: marc5
Jeff Hanson
marc5
Message 7 of 7 (226 Views)
02-21-2014 09:56 AM in reply to: loboarch
COOL....Thanks, that did it! Have a great day.
Marc
