does the window frame and glass actually curve in your design? If so, you
will need to build a custom window curved the same radius as your wall. If
its more of a segmented window where the frame and glass are straight, but
are multi-faceted to appear like they follow the curve, then you can make a
window which is built ths way as well. Both *could* be parametric, but most
likely these are going to be special windows built to a certain size to meet
your need just at this one location.
wrote in message news:5684404@discussion.autodesk.com...
How do i do that? Do i have to create a new parameter when im editing family
types?
