Windows bending???
3 REPLIES 3
perthmod
183 Views, 3 Replies
Windows bending???
I have placed a tangent wall and have tried to place a window, but the window stays straight and wont bend with the wall and it doesn't show throught the wall.
3 REPLIES 3
in reply to: perthmod
You need to create a curved window family that meets your desired radius.
wrote in message news:5681559@discussion.autodesk.com...
throught the wall.
perthmod
How do i do that? Do i have to create a new parameter when im editing family types?
does the window frame and glass actually curve in your design? If so, you
will need to build a custom window curved the same radius as your wall. If
its more of a segmented window where the frame and glass are straight, but
are multi-faceted to appear like they follow the curve, then you can make a
window which is built ths way as well. Both *could* be parametric, but most
likely these are going to be special windows built to a certain size to meet
your need just at this one location.
wrote in message news:5684404@discussion.autodesk.com...
types?
