Windows and Doors dimension on plan view
3 REPLIES 3
3608 Views, 3 Replies
Hello everyone,
the printout is A1 so the sheet has plenty of space to accomodate extra text such as dimension for windows & doors.
is there any way I can do it smartly? instead of manually inserting dimension text for each door and window.
image there..
thanks.
3 REPLIES 3
constantin.stroescu
in Family Editor make a new Window Tag ( or change an existing one)
Make a Label with all the neededed informations and load it under a new name in your project.
See the attachments
Constantin Stroescu
sorry ...do not change an existing one, but make a copy of it...
Constantin Stroescu
loboarch
I gave a response to another post last week looking for something kind of like this.  You can take a look at this thread and see if it might help.  It has a couple of images and a sample family you can take a look at and maybe make some slight modifications to in order to get waht you are after.
http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Tags/m-p/3808306#M67328
Jeff Hanson
Principal Content Experience Designer
Revit Help |
