Revit Architecture
Valued Contributor
SDG-Kelly
Message 1 of 3 (1,405 Views)
Window Trim in Revit
1405 Views, 2 Replies
02-18-2009 04:48 PM
Hey all,
Dose anyone have a good method for adding a very specific window/door trim to a project without customizing each and every window/door family project wide? Thanks for any help you can provide.
Distinguished Contributor
melarch
Message 2 of 3 (1,405 Views)
Re: Window Trim in Revit
02-19-2009 03:14 AM in reply to: SDG-Kelly
You create a faced based family or use the Create In-Place tool under the Modeling tab to create windows trims using a sweep.
Mel Persin, aia
Scott_Womack
Message 3 of 3 (1,405 Views)
02-19-2009 04:55 AM in reply to: SDG-Kelly
You can also add the trim to the window families, with a Yes/No instance parameter to control the visibility of the items.
