Can anyone tell me why the symbolic lines in this window family file don't show up properly in project plan view? The window just shows up as a blank rectangle with a hovering indication that the symbolic lines are being masked. Any help is really appreciated. When the window is raised up in the wall the symbolic lines show up but the opening is gone.
Mike
Most likely, it's the header of the window. Usually that part should be set to not display in Plan/RCP.
Thanks for the reply. Turns out I was just using regular lines and not symbolic lines. Duh.
