Window Family Problems
2 REPLIES 2
paul53_7
222 Views, 2 Replies
Please see attached Revit File
I am creating a window, i have inserted a few parameters width , height etc. But when i try and change these widths and heights my upper frame does not move with it. See file for better explaination.
Any help would be appreciated.
2 REPLIES 2
downing.nigel
in reply to: paul53_7
In general - get it working with flexing of the reference plane before you worry about the geometry.  Put in reference plane and place only one dimension string to control it. (dont put in multiple dimensions in multiple views to the same plane.   Assign a parameter to control the dimension.  Flex it to ensure the reference plane moves when you change the parameter (maybe have 2 family types for testing/flexing).   Lock geometry to the reference planes and not to other geometry. Good luck.
paul53_7
in reply to: downing.nigel
Would you have any examples you could show me?
Still abit new to creating families.
Thanks.
Rail Community
