i have looked through the discussion board and cannot find an answer to How to create a Winder staircase.
The as built staircase is a straight run with the first 3 or 4 treads winding. I cannot figure out what my settings need to be etc. HELP!!
Solved by Alfredo_Medina. Go to Solution.
There are, at least, 2 ways:
Al, Thanks that is what i did. I drew the stair boundry and placed the risers in. seemed to work fine. I get the error message below: Stairs require no less than 2 boundries. (the MS paint image dropped some of the risers, trust me they are there)
See that green horizontal line? That should be a riser (black line), not a boundary (green line). The boundaries areusually two sets of lines, on the sides of the stairs, not intersecting each other.
Why isnt this board (not sure what it is called) not running parallel with the stair case??
