Revit Architecture
Active Contributor
jmackniak
Message 1 of 5 (688 Views)
Winder Stairs
688 Views, 4 Replies
01-14-2013 09:16 AM
i have looked through the discussion board and cannot find an answer to How to create a Winder staircase.
The as built staircase is a straight run with the first 3 or 4 treads winding.  I cannot figure out what my settings need to be etc. HELP!!
See that green horizontal line? That should be a riser (black line), not a boundary (green line). The boundaries areusually two sets of lines, on the sides of the stairs, not intersecting each other.
Alfredo_Medina
Message 2 of 5 (661 Views)
Re: Winder Stairs
01-14-2013 07:06 PM in reply to: jmackniak
There are, at least, 2 ways:
  • With the stair by sketch method, modify or create risers manually, with the Riser tool.
  • WIth the new stairs by component method, use the Winder tool.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Contributor
jmackniak
Message 3 of 5 (644 Views)
Re: Winder Stairs
01-15-2013 05:34 AM in reply to: jmackniak
Al,  Thanks that is what i did.  I drew the stair boundry and placed the risers in. seemed to work fine. I get the error message below:  Stairs require no less than 2 boundries. (the MS paint image dropped some of the risers, trust me they are there)revit stairs.png
Alfredo_Medina
Message 4 of 5 (637 Views)
Re: Winder Stairs
01-15-2013 05:54 AM in reply to: jmackniak
Active Contributor
jmackniak
Message 5 of 5 (606 Views)
Re: Winder Stairs
01-17-2013 09:11 AM in reply to: Alfredo_Medina
Why isnt this board (not sure what it is called) not running parallel with the stair case??revit stairs2.png
