Can someboday help me in changing the parameters Width on Side 1 & Width on Side 2, that are available in a Rectangular Mullion. I need to reduce them but those are locked in the type properties.
Solved by Chris.Aquino. Go to Solution.
The parameters are greyed out because they are driven by another parameter (most likely through a forumla). You can check this by going into Create > Family Types in the family. If they are being driven by another parameter, you'll have to change that parameter, or break the connection.
