i have a parkade in a file with three other buildings. i'm trying to get a ramp for it but when i try to make it revit says that its not long enough to reach the next level. it doesnt matter what i change the slope to still doesnt work.
Solved by chrisplyler. Go to Solution.
Assuming you have the Base Level and Top Level set to levels 1 and 2 respectively, a ramp tries to go from one level to the other. Select the ramp, edit the family, and adjust the parameters "Maximum Incline Length" and "Ramp Max Slope (1/X)" to values that will allow it to do so.
xtn
