My Revit 2014 is very slow. Previous Revit 2012 worked fine. But I needed latest to open others student's files. I also have Google Sketchup, AutoCAD they work pretty fast. But in Revit if I select something or zoom out time donut displays for 3-5 seconds. Please help me.
Thank you,
Iroda
It could be any number of things. Please post the specs of your computer (OS, processesor, graphics card, RAM) and I'd be glad to make some observations. Also, when you say "slow," are you referring to any specific task (panning, zooming, creating walls, creating doors, etc.), or is everything consistently slow (from opening the project to manipulating model elements)?
Sorry to tell you this, but you've got a couple of problems. For one, you're i3 processor is a little on the slow side. I'd recommend at least an i7, and the higher the speed, the better. Also, 4 GB of RAM is nowhere near enough. You're going to need at least 8, although I'd recommend 16. Also, it sounds like you're using the onboard Intel graphics card, which just isn't going to cut it. If you have a laptop, then you're out of luck. If you've got a PC tower, then you can add a graphics card. Doesn't really matter which one, but try and find one with 2GB of onboard RAM.
To break it down, the processor and RAM handle most of the modeling tasks (creating walls, editing schedules, etc.), while the graphics card handles things like panning, zooming, refreshing views, etc.. Sorry for the bad news, but hopefully you're using a school computer, and can let them know that their machines are not up to the task of running Revit.
Hope that helps.
Yeah, completely agree with Ross. Revit isn't slow, it's your machine. I wouldn't even give that thing to an administrator using word processing. I am surprised Revit 2012 ran on that to a standard you seemed to have been happy with.
Upgrading to 2015 will also help marginally. They have made some performance enhancments which I have noticed. It just feels a little zippier at the cursor.
These are the recommended specs for Revit 2014. Starting from minimum entry level to performance.
Thank you so much for your answers, rosskirby and damo3, Now I realize my computer is not capable enough.
Buying new computer would be too unexpected expense to a student like me. Yes it is a labtop, which I both need to use it in school and home.
I will also try installing Revit 2015, since demo3 told it can help hopefully.
I also learned from other posts that if I turn on "Hardware accelarator" it would work faster, it that true?
Thank you so much for helping,
Iroda
Even if my computer is not that new. I wonder why most of my classmates still use their old laptops with flying Revit 2014,
When I turned off Hardware accelarator, I saw a message below,Do you think this messege is part of the problem?:
"Unknown Video card: The installed video card 'Intel(R) HD Graphics Family' has not been tested with Revit. You may continue to use Hardware Acceleration. If you experience graphics display issues, you should: - Turn off Hardware Acceleration"
So I turned it off, My revit is a little bit faster.
Does it have any bad effects on the projects that I start opening on?
Thank you very much for your help,
Iroda
Hi Iroda.
Turning off hardware acceleration could help a little bit, but it will make some things (ike panning, zooming, and some graphic modes) slower or completely unavailable. With only an onboard graphics card, there's really not a whole lot you can do to boost the performance of your laptop. For a decent laptop capable of running Revit as a student, you're looking in the neighborhood of $1200-$1700. If you just want it for modeling, and have more powerful school computers available for rendering, then you would be on the low end of that range. Otherwise, more money usually equals better performance (to a point).
