Revit Architecture
dtiemeyer
Message 1 of 4 (245 Views)
Why is the 'Revit Wishes' forum closed?
245 Views, 3 Replies
01-28-2014 06:06 AM
Anyways,
Here's another wish list item. I want the 'Sheets' portion of Project Browser to behave like AutoCAD's Sheet Set Manager when I right click on a sheet, I have the option to send Full/Half/PDF prints. Also CTRL + Select for multiple sheets or send an entire 'subset'.
Striving to be a WOMBAT, Waste Of Money, Brains, & Talent...
⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you!
Product Support
Alaaeldin_Alsahli
Message 2 of 4 (203 Views)
Re: Why is the 'Revit Wishes' forum closed?
01-29-2014 06:46 AM in reply to: dtiemeyer
Here is the link for a wishlist
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
dtiemeyer
Message 3 of 4 (173 Views)
01-30-2014 12:57 PM in reply to: Alaaeldin_Alsahli
Thanks Alaaeldin for the link, but simply sending 'wishes' to an email box that only Autodesk sees is a BIG STEP BACKWARDS from having a forum where end users can DISCUSS each other's ideas and add to them, support them, etc.
Product Support
Alaaeldin_Alsahli
Message 4 of 4 (157 Views)
01-31-2014 05:52 AM in reply to: dtiemeyer
Wishlist goes directly to autodesk development team, and they will take it in consideration if the feature doesn’t exist or important or if there is a lot of people send the same wishlist. What I am afraid of is the feature you are asking for, you could use it somehow when comes to printing. There is an option (print Range where you could select (Selected Views/sheets)) and then select the view/sheet you want, you could always try and see how thing goes. Support team is here to contribute for help.
Alaaeldin Alsahli
Post to the Community
New Post
Need installation help?
