Anyways,
Here's another wish list item. I want the 'Sheets' portion of Project Browser to behave like AutoCAD's Sheet Set Manager when I right click on a sheet, I have the option to send Full/Half/PDF prints. Also CTRL + Select for multiple sheets or send an entire 'subset'.
Here is the link for a wishlist
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Wishlist goes directly to autodesk development team, and they will take it in consideration if the feature doesn’t exist or important or if there is a lot of people send the same wishlist. What I am afraid of is the feature you are asking for, you could use it somehow when comes to printing. There is an option (print Range where you could select (Selected Views/sheets)) and then select the view/sheet you want, you could always try and see how thing goes. Support team is here to contribute for help.
