Hi Expert,
I try to create the wall by folowing pts, but i got two errors
Error message
Elements Can't make Extrusion. Walls : Basic Wall : Generic - 6" : id 161195
Elevation Profile sketch is invalid. Walls : Basic Wall : Generic - 6" : id 161195 Sketch : id 161197
used pts as following:
XYZ[] pts = new XYZ[] {
new XYZ(5.675844469, 8.769334161, -5.537348007),
new XYZ(5.665137820, 8.771332255, 2.956630685),
new XYZ(7.672569880, 8.396698044, 2.959412671),
new XYZ(7.647794054, 8.401321803, 1.146156291),
new XYZ(7.623735235, 8.405811750, -0.614624778) };
i can verify these five points on the same plane, and this plane vertical to XOY plane.
i used these pts created ModelCurve as attachment.
Could you give me some ideas? Thank you in advance.
I am not sure of what you are trying to create. A wall is a system family, you cannot 'create' a wall outside a project.
What exactly are you trying to do or have it look like?
LD
