Why can't I do edits in a 3D view? Interior carmera sweep wall....
5 REPLIES 5
billy007
177 Views, 5 Replies
We do I all of interior views for clients and I'm starting to get to the point of well I can't post that word but, why can I not sweep my walls like moldings or do really any edits in a 3d view?
What is the easiest way to do edit on the interior if not in a 3d view?
5 REPLIES 5
in reply to: billy007
You can edit in a 3D view. But not in a perspective view. Edit interior
views in interior elevation views.
Or apply a section box to a 3D view.
wrote in message news:5678911@discussion.autodesk.com...
billy007
I don't like making 50 elevations views just so I can get around the building.
I hide or override exterior walls to transparent and then do the best I can to get most interior sweeps and edit I need but, that works great but on big projects it time comsuming! I like to make persective view of the exact area I want to see and edit that stuff!
What do you mean by add section box to a 3D view?
A section box allows a 3D veiw to be cut so you can look inside a project.
It is a property of 3D views.
Are you drawing just for design or for both design and CD's? If your drawing
for both, them adding the interior elevations will be a big time saver as
the project develops.
If your just doing it for 3D work - use section boxes and learn how to use
the dynamic view (F8) to set your 3D view to the correct area to work.
If you only want to work in perspective - use SkecthUp or 3D Studio.
If you re placing lots of sweeps - then you should look at why you are
placing so many. You can probably save a lot of time by adding the sweeps to
the wall type rather than adding them one by one. I do base trim as a floor
slab edge. This allows me to do it all in plan very quickly.
For ceiling trim I use a roof fascia attached to a model line on the
ceiling surface. Again very fast and easy to do in 2D. For simple
rectilinear spaces, I sue a generic family of trim. I can place the
rectangle in a couple of mouse clicks and the trim is set.
wrote in message news:5679045@discussion.autodesk.com...
building.
billy007
Mostly in offices we do more interior renderings and those spaces that are big money items the client want to see what he is spend his millions on! Most other room we don't bother adding trim or crown molding but I will have to try using that model line for the ceiling trim that nice! I use the F8 to set up all my views and adj. my walk thru. We are a smaller office and if others get into one of my projects I'm in they don't know or understand most things so I don't like to add things or sweeps in wall family or stack wall family. They don't get what they are using and why is there trim or molding showing up on these walls? It's because you used a wall with it built in!
Only been using revit 4 months so still getting there as a office! lol Some quicker than others!
Thanks I'll have to try those ideas out!
I'm not talking about F8 for walkthroughs....
Rather F8 > Orient to a View... If you're not using that - you're missing a
big tool. And don't forget the saev button.
wrote in message news:5679217@discussion.autodesk.com...
built in!
