Revit Architecture
Revit Architecture
Distinguished Contributor
kwg06516
Message 1 of 2 (185 Views)
why am I seeing tops of components above the current cut plane?
185 Views, 1 Replies
09-13-2013 07:09 PM
I made this custom plate W-shape for my as-built from hell and for some reason I can see the top even though it's over six feet above the cut plane.  I changed another column (a W-shape from the Imperial library) to the custom and the top is not visible.  It's cut like it should be.
I should be designing by this point and I'm still as-builting this project.
AutoCAD 2010
AutoCAD LT 2013
Revit Architecture LT 2013
In Family Editor: Modify > Family Category and Parameters >Family Parameters >Parameter > Show family pre-cut in plan views - uncheck this option > reload the family back into the prokect....you will be able to see now , the correct cut...
constantin.stroescu
Message 2 of 2 (145 Views)
Re: why am I seeing tops of components above the current cut plane?
09-14-2013 01:45 AM in reply to: kwg06516
Constantin Stroescu
BIM Manager AGD
