instead of using filled regions with Solid White patterns, use a filled
region with the pattern set to "no pattern". This will still wipeout
everything underneath it, but will not cause problems with black squares
when exported to DWG, DWF or PDF.
wrote in message news:5166944@discussion.autodesk.com...
Use a filled region with solid fill - white. This is view specific as are
all drafting tools and dimensions/annotations.
Why would you want to change or over-write the actual dimension?
Mel Persin, AIA
