Hi!
Where are the Model Patterns? In which folder?
I want to edit them, but I can not find them?
I also want to edit Bump files (rendering image), for example:
How would you do it?
Thank you!
Matti Kettunen 🙂
Solved by kathryn.langan. Go to Solution.
Model Patterns are located in the Revit.pat file at C:\Program Files\Autodesk\Revit Architecture 2011\Data.
What kind of edits do you want to make to the bump files?
Hi!
And many thanx for your reply and advice, Katie! 🙂
Model patterns found!
The link (Revit Kid) was very good! And the video in it solved my problem. A little bit complex are those *.pat files to edit, but I managed to do what I wanted.
Bump files:
I want to create a rendered wall finish style, where is this kind of elements. See illustration. There is 25 mm bar and 100 mm board. See ill.
Thanx,
Matti Kettunen 🙂
Hi Matti,
So are you actually modeling the boards and bars, or do you just want to show them through the patterns and rendering material?
There are some existing threads on board & batten walls that you might want to take a look at:
Please let us know if this helps!
