When what you see isn't what you get...
1 REPLY 1
Keith_Wilkinson
235 Views, 1 Reply
We've been using 'layered' elevations for a while to good effect - it allows us to have different view settings to make parts of our building soften into the background and adds impact to the overall presentation of the drawing.
However I have just tried using the same approach to sections and I'm getting some odd results - as I can't share project info here I've set up a small sample project to highlight the problem.
Image 1 shows what I see on screen in Revit - this is an elevation with consistent colours applied and shadows turned on and then a section overlaid on the top which is set to hidden line with no shadows.  The screen shot is exactly what I'm wanting in terms of how the view /should/ look.
Image 2 shows the PDF I get when I print.  The actual printer makes no difference I should add as the result is the same regardless.  As you can see the elements that are actually cut still show as expected but the elevation parts of the section are over ridden by the elevation behind.
Is there as setting that I'm missing somewhere or can someone explain why Revit isn't plotting what I see on screen?
*edit* I should add I get the same results in both 2013 and 2015
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
1 REPLY 1
current propsed solution for this from Autodesk is to use a masking region sandwiched between views - so in this case placed over the elevation and behind the section.  While not ideal I think this is pretty workable just now.
Maimonides
Rail Community
