I'm wondering what is the best and easiest way to show falls, pits and drains on an open-air car park slab on ground?
I just want to match the hydraulic engineer's drawing, which was done with AutoCAD. At this stage, I doubt I will need 3D geometry for these things.
Thanks in advance,
Nige'
Solved by constantin.stroescu. Go to Solution.
In my opinion this a problem of choice.
Constantin Stroescu
I was thinking of importing the consultant's drawing using Link CAD and hiding the things I don't want to see. I already have a basic flat slab in place and I won't be responsible for the civil works.
Thanks for your help.
It.s OK as you say. The only thing , where you must be carefull is to ask the consultant engineer to make a good layer structure so to can hide layers that you don't need in your file. You can import only the layers you need or hide those you don't want....
Constantin Stroescu
