Why there is no infill when there is a hight elevation change? the path is a "building pad", and I'm pretty sure normally it's filled with dirt....
Did I do something with the site setting????
Please help...
sixingno1, That's happened to me before, as well. Two solutions could be to add a wall as you would in reality; it's a pad for something, yes? Another solution would be to delete the building pad, then edit the topography by adjusting the respective grades manually that define the pad. Yes, that would be time-consuming. That's all I can think of.
Hello and Welcome to the Discussion!
There is no automation for infilling - it will all need to be done manually as nicesacve2000 has said.
LD
Lisa, You mean I got it right ??? Cool, extra chocolate for you; have a nice weekend. Dan
Another option is to create a new pad adjacent to the "cut" areas; you'll have to "new pad type" like you would for a new door type. Having said that, I notice the topography is sloped. I've heard you can slope a building pad, but I don't know how to do it.
