I think remember someone doing this a while back...
In your wall style, add a sweep at the top and bottom of your wall, which
will show the detail you require in section.
Paul Monsef
TSA architects, pllc
"Don Sutherland" wrote in message
news:4920267@discussion.autodesk.com...
Is there away I can show the 2x top plates and 1 bottom plate in a wood
wall type and show up in the detail view in the cross sections. I would like
the top to be set to the elevation top plate line and the base at the base
plate line.
If the top plate line changes in elevation from 8' to 9' the double plates
would also move up.
This would save time when doing the cross section veiws.
Don Sutherland, Architect, AIA
Email: don@dwsarchitects.com
