I created a plan using the Generic 8” masonry wall type, set up the column grids, and placed the walls to correspond to masonry unit module dimensioning. After that was complete, I changed the wall type to a masonry wall with gyp. bd. on the inside and stucco on the outside. Even though the new wall has the same core width, all the dimensions are now off. Aligning the wall core face to the grids doesn’t seem to work, and I’m not sure you can move a grid. Do I start over, or did I do something very rookie-ish?
Phil
Solved by Alisder.Brown. Go to Solution.
The strange thing is I did put the original walls in using the exterior face of the core, so presumably the walls wouldn’t shift. I'll keep working at it. Thank you for your quick responses.
By the way, is there a way to rotate the plan view so that you are looking at angled portions of the plan orthogonally (like setting the UCS in Autocad)?
Phil
PhilvK
Re the wall moving issue, Loboarch covered it. the Location line should anchor that part of the wall wherever you draw it.
With regards to the rotating the view, couple of things you can do without having to rotate True/Project north.
One option would be to make the crop region visible, select it, and rotate it X deg. If you are doing this you need to rotate the crop region opposite of what you want the view to be rotated, for example, you need the plan to be rotated 17.5deg clockwise, so you select the crop region for the view and rotate it 17.5deg COUNTER-clockwise.
Another option would be to, from your floor plan, create "Scope boxes" for the regions that are angled (East wing, west wing for example) Rotate the scope boxes to match the angle of the walls (you can have as many as you like) then create dependant views, each one using a different scope box, and because you rotated the scope box in the "parent view" the dependant views with said scope boxes will appear orthogonal. See screencast below for a quick example:
https://screencast.autodesk.com/Main/Details/1440d536-a79e-49cd-b907-34f616167883
Hope this helps
