I would like to show Walls with dual cut patterns.
Example: Crosshatch and Solid Fill - Gray
Any ideas ?
Thanks in advance.
That is a good solution. We just need to make sure no other families(objects) in the model do not have a material with a shade.
Since the walls are the only objects we are needing this look.
The Project time frame did not allow us to slow down at all for this issue.
That being said. I should let you know this is a renovation Project using Phasing.
I do not know if that changes anything.
We were able just now to get the results we needed by creating New Wall Types with Gray shading and Existing/Demo Wall Types with white shading.
