There is no simple "attach to stair" command. However under s spiral stair
is much easier now (in 2009). You can use an in-place family for the wall
under the stair and form it with a swept blend. This works well for under
spiral staircases.
Jeff Hanson
Autodesk - AEC User Experience Team
Manchester, NH
wrote in message news:6018358@discussion.autodesk.com...
What is a simple way to attach walls to stairs? I found a tuctorial from
05' that goes thru a work around. But has revit not created an easy way in
4 years?? I have a spiral staircase and I need to attach walls to it in
front and behind.
