Wall Wrapping Width
5 REPLIES 5
870 Views, 5 Replies
Wall Wrapping Width
Hello, newbie in the forum here
I wat to change this dimension of the wrapping material (please see image).
Is it possible?
Tags (1)
5 REPLIES 5
constantin.stroescu
I use for this a workaround:
I make two layers of the same material and I wrap only the exterior one...
Constantin Stroescu
in reply to: constantin.stroescu
Thank you for the sugestion 🙂
I think this is the result you are talking about (see image).
However can we do something about the line between the two layers?
I tried the Linework tool but still a grey line remained underneath.
constantin.stroescu
The same happens to me...but I use another workaround and for me it works:
Visibility/ Graphic Overrides >Model Categories > Walls - expand the submenu.and uncheck Common Edges.
You have also to check Override Host Layers > Cut Line Styles (otherwise the border lines will disappear...).From here you can set also the border line width override...
Constantin Stroescu
Thanks!!! That solved my problem. 🙂
The only thing that remained, that i recently found is - revit doesn't make wrpas in section.
I guess that I'll be using detail lines and fill patterns there.
constantin.stroescu
you are right about sections...
Constantin Stroescu
