wall wrapping at head of window/door
18 REPLIES 18
Message 1 of 19
FinearcLtd
3845 Views, 18 Replies
Anybody knows how to to wrapp at the head or sill of inserts? nice control in plan but no control in section...
18 REPLIES 18
Message 2 of 19
alan.quinn
in reply to: FinearcLtd
If you enable wrapping at inserts the outside layer will wrap around at the sides but not the head and still. This is by design and the application is working as expected. See attached images for details. However, I'm not sure I fully understand what you mean by "nice control in plan but no control in section...".
Here's a few links on Wrapping:
Layer Wrapping
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-69B6DC75-56A9-4F35-BE24-80048360E2BB
Setting Layer Wrapping
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-B680A2D3-8051-44E4-A93D-68768896DF5E
If I misunderstood your questions please add additional notes and/or a screen shot. Thanks for posting.
Message 3 of 19
FinearcLtd
in reply to: alan.quinn
Hello Alan,
Thank you for your reply. I am replying outside the forum so as not to embarrass you with what I have to say.
I have been working with Revit for the past 14 years. I must inform you that very few of the improvements our office asked for where addressed in the development process of the software. I find it very annoying that your company does relatively little to make major necessary improvements in the software. My last request is merely one out of many that I have presented over the years. These drawbacks make the use of the software less and less worthwhile for us. If you do not plan to make such improvements in the software that allow for as little as possible use of 2D drafting than we may consider dropping the whole service altogether and seek better solutions elsewhere. Your tone of reply has been your company's mantra for the past decade. You should design your software to suit the designer's needs and not to please the programmers. Whether it is expected that the software should work this way or another, we couldn't care less, it should more than anything else work as we, the users, need it to work!
My office does a lot of public relations for you software in our country, but lately we are getting tired of waiting for the obvious while paying substantial sums of money to stay tuned in.
Please pass on the message to your superiors. A company of your scale should be able to do much better with its R&D department.
Respectfully yours,
Architect Eyal Bleiweiss
Finearc Architects Ltd. www.fa-arch.com
Cellular 972-54-4215204 Tel 972-77-7867861/2
31a Hatchelet Street Hod Hasharon 4526461 Israel
Message 4 of 19
damo3
Um, this wasn't outside the forum.... and why would he be embarrassed? All he meant was you aren't doing anything wrong so don't tear your hair out. He asked a few questions to try and further assist, I didn't see the further info in your rambling... so if your serious about wanting a possible solution....
________________________________________________________________________________
If you find posts have solved your problem, please don't forget to mark them as 'SOLVED' to help others with similar questions. - Thank you.
__________________________________________________________________________________
Message 5 of 19
Keith_Wilkinson
in reply to: damo3
I think a lot of people feel frustrated by what they perceive to be slow development in particular areas - actually I don't know of a single Revit user I've spoken to that doesn't.  It would be nice if some of the recurring issues were addressed but I've long since given up holding my breath on that - I give suggestions for improvements as and when I can and hope that one day they may see the light of day.
With regards to the original question.  I've often found it odd that wraps only work in plan and not section (ie window jambs but not head and cill).  Alan has stated that Revit works 'as expected' which it does but that doesn't mean that it works the way people need it to.  I think it would be good if there was an option for wall wraps at head and sill as well personally.  A lot of the time I wouldn't use it but there would be times where it would save a lot of hassle.
cheers
K.
"Give a man a fish and you feed him for a day; teach a man to fish and you feed him for a lifetime."
Maimonides
Message 6 of 19
damo3
Yes of course but thats not a Revit thing, that's an Autodesk thing.
I understand frustration, guilty of a line or two myself written here with only emotion behind it, but there is always something productive to continue.
Anyway, what scale is your head and sill that you require wall wrapping? Isn't this covered in details?
My 2 cents.....Text editor springs to mind as needing development before wall wrapping.
Message 7 of 19
Keith_Wilkinson
in reply to: damo3
Text editor definitely needs improving!!  These things shouldn't need to be sequential, we talk as if there is just a single developer at Autodesk working on Revit... (or maybe there is... )  😉
If you use the argument of covering head and cill wall wrapping by using details then why bother having wall wrapping at all as the same argument would apply in plan surely?  FWIW I would expect to see it on a 1:50 section in certain circumstances but for me it would mostly be of use if I had a deep reveal where I wanted the external leaf of the wall to wrap inwards.
I don't think there is anything wrong with venting a bit of frustration on here every now and again - but what people need to realise is that the majority of people who post on here aren't developers - they are just the guys trying to help us out, so venting at them really isn't fair.
Maimonides
Message 8 of 19
damo3
One guy. Works part time. 🙂
Yup, applies in plan. The way i see it, at scales smaller than 1:20, a 10mm plasterboard layer is not clear with the rest of the wall lines. By the time i get to 1:20 i am adding detail lines and filled regions anyway. So yes, never been a problem for me but everyone has different expectations and workflows.
P.s. im sure it is sequential... they have a whiteboard in the discussion room, 2015 had nothing new hence the time for a mid year upgrade with R2!
Message 9 of 19
STONEMAN123
in reply to: damo3
Interesting topic. For me the problem is that in an internal room elevation one sees the window ope and presumes that the ope is from finished face to finished face. When in actuality it is the structural ope we see. So when we dimension the ope it's not the same as the dimension that will be given in the plan once the plastered reveal is shown
Message 10 of 19
I read this several times and still can't make any sense out of it, per se and with regarding the original question. Care to elaborate?
In my opinion, it is a programming error. There are bandage fixes such as Cut profile, Parts, etc... but they really should make it to behave consistently between plan and section.
Message 11 of 19
in reply to: ToanDN
…what irks me even more, is that the cladding materials that do wrap at inserts and ends, aren’t picked up in quantity take offs!
Message 12 of 19
in reply to: barthbradley
…oh, and then there’s the fact that you can’t dimension to the core edge of a wall with an end wrap. Can’t snap on it. Can’t align to it.
C’mon. Really?
Message 13 of 19
damo3
@Anonymous
Yup, its really annoying.
Revit idea here: https://forums.autodesk.com/t5/revit-ideas/dimension-walls-when-wrapping-at-ends-active-current-limitation/idi-p/6905605
Message 14 of 19
Ilic.Andrej
Family parameters can help with wrapping in sections. I've managed to create a workaround:
If you are wrapping not only Facade but also the insulation, this family will work only when the window casement is positioned next to the exterior face of the core. However, if you are wrapping the facade only, you can position it closer to the interior face. Usually, blinds force positioning windows towards the interior, but that can be defined with a different family.... Also, this family allows option for displaying ventilated facade. It took me alot of time to make it so tell me what you think.... I'm willing to share it, so feel free to download it from my gdrive:
https://drive.google.com/file/d/0B95C_q8GJGDVUTkxLUlwVWxuT0k/view?usp=sharing
Also, if you like it but have some trouble using it, don't hesitate to ask me.
Andrej Ilić
name spelled phonetically: ændreɪ ilich
M.Arch.
Autodesk Expert Elite Alumni
Message 15 of 19
in reply to: Ilic.Andrej
@Ilic.Andrej: Be happy to provide you feedback, back I'm not quite understanding what you/re saying, and I cannot open your  RVT file from the link you provided. Can you post it as an attachment instead?
Message 16 of 19
Ilic.Andrej
No problem, I attached here...
I ll try to be more understandable 🙂 What I'm saying is that this workaround works for windows which are positioned near the layer which is being wrapped. It just so happens that they are also connected to the core which is where they should be.
Andrej Ilić
M.Arch.
Message 17 of 19
Ilic.Andrej
I did some fix
Andrej Ilić
M.Arch.
Message 18 of 19
What am I looking for? I don't see anything different about the family, or with how it improves wall wrapping in project.  Sorry, you probably expected a different reaction, but I don't know what I should to react to. Help me out.
Message 19 of 19
Ilic.Andrej
As the picture shows, it mimics wrapping in the section. There are parameters called "Wall - Wrapping/ Exterior" and "Wall - Wrapping/ Interior". They affect void constraints. Since I used multiple voids, I can also control "Void Extrusion End" (void height) which can be used to create wrapping in the section. As I said before, this works when the window is positioned against the exterior face of the wall core.
Andrej Ilić
M.Arch.
