Wall visability
7 REPLIES 7
Message 1 of 8
193 Views, 7 Replies
Wall visability
I have a framing plan that some walls will show up as simple 2 line walls in plan view and some that show up with poche and heavy outline. My question is why do they show up differently in the same plan when everything about them is identical. Height, constraints, offsets etc. I have discipline set to coordination. Any help would be appreciated.
John Fleming
7 REPLIES 7
Message 2 of 8
sbrown
are they 2 diff. wall types? could one have a course scale fill set and the other doesnt?
Message 3 of 8
sd, they are the same type. very perplexing.
Message 4 of 8
John,
Can you post an example file (stripped down of any unneeded items) that
shows this? It will make pinpointing the exact issue much easier.
happy BIM'ing...
Beau Turner
Avatech Solutions | BSG Senior Consultant
Autodesk Architectural Desktop Certified Expert
Will render for food... - Digital Media Blog
http://www.rndr4food.blogspot.com
the Vizdepot - Your visualization resource
http://www.vizdepot.com
wrote in message news:4916230@discussion.autodesk.com...
Message 5 of 8
Under "Structural Usage" in the wall properties are some set to bearing
vs non-bearing?
Robert Witte
> John Fleming
Message 6 of 8
All non bearing
Message 7 of 8
sbrown
just delete and redraw, is there any chance there is 2 walls on top of each other? Or a plan region.
Message 8 of 8
Problem was that the walls were not stopping at the bottom of the floor. Also, couldnt post flie because the smallest that I could make it was 3.2mb. There were only 8 walls and 1 floor. Seems a lttle large to me but the full file is 40mb. 2 Storey house with basement. Is this typical?
