Wall that is Curved, Non-plum and has Ccurved Top
3 REPLIES 3
266 Views, 3 Replies
So can Revit do all or any combination of:
1) A straight or curved wall that is not plum. It may lean backwards for
example 10 degrees.
2) A curved wall that also has a curved top of the wall (parabola???)
3) A straight wall that is curved at the top (which I know can be done) but
also not plum.
AND THE ULTIMATE:
4) A curved wall that has a curved top (concave or convex) and is also
leaning back at 10 degrees (not plum).
Many thanks.
Andreas
3 REPLIES 3
1) Yes
2) Yes
3) Yes
4) Yes
But for each of these, its about modeling techniques to create them. You
will model a Mass in the shape that you need and then apply a Wall to the
face of that shape to create the walls you describe.
"Andreas" wrote in message
news:6018163@discussion.autodesk.com...
example 10 degrees.
also not plum.
AND THE ULTIMATE:
Many thanks.
Andreas
You may need to use "openings" to cut the shape you want (if you are having trouble making it with a single "mass"
haha... so is CATIA not workin out for you, Gehry?
