Hello all,
I am really new to Revit. I have been using it for 3 months. Here is my question and my problem:
We have a diamond shaped wall tag. When I add the leader, it will start from one of the corners of the diamond. Works well. I took that family, did a save as and added another parameter. This parameter is a tag by tag basis, so that I can a note to each tag. I'm doing this to denote a finished wall ht. When I add this note to the tag, it then trys to move the leader away from the diamond. Its apparent that it is trying to center it about the text. How can I make this thing work so that when I place this tag in North, East South and West position, it will take the leader line from one of the points on the diamond. I have attached the file for your review. Thanks
