Wall sweeps
10 REPLIES 10
Message 1 of 11
550 Views, 10 Replies
Wall sweeps
I have tried 2 methods of generating a parapet cap:
1 - Creating a wall style with the sweep.
2 - Added a host sweep.
The problem is that using either method or a combination of both methods
doesn't always work. I still end up with some caps that don't miter
correctly even after editing. Sometimes, different intersections will miter
and others won't. Does anyone have any ideas? A newbie, I am probably
doing something wrong.
Thanks!
-Jawknee 99
10 REPLIES 10
Message 2 of 11
I have the same problem. I would also like to know how to edit a wall
profile, say for a stepped parapet wall and get a sweep around and over it
nicely mitered. I don't think it can be done in Revit yet my client wants
it. What do I do?
"Jawknee99" wrote in message
news:5084745@discussion.autodesk.com...
Thanks!
-Jawknee 99
Message 3 of 11
Can you post the file ?
Message 4 of 11
Modeling->Create->Walls->Solid Form->Solid Sweep Pick edges....
One of the tutorials covers this...
"Storm Petrel" wrote in message
news:5085460@discussion.autodesk.com...
it. What do I do?
Thanks!
-Jawknee 99
Message 5 of 11
For some reason it won't post. Probably too big but I stripped a bunch of
stuff out of it.
wrote in message news:5085502@discussion.autodesk.com...
Message 6 of 11
How big is it ?
Message 7 of 11
5 MEG, - I'll try again
wrote in message news:5085884@discussion.autodesk.com...
How big is it ?
Message 8 of 11
How big is it ?
Message 9 of 11
You can email it to me daniel.hurtubise@@lemaymichaud.com
Remove one @
Message 10 of 11
Use the Create-in-place tool on theModeling Design tab to sweep a profile along your wall. Also, to get Hosted sweeps to connect use the Join Geometry tool on the toolbars above the optio bar.
Mel Persin, AIA
Message 11 of 11
I have added a detailed trim sweep to a wall type and sometimes they do not blend together at corners. Any ideas of what I may be doing wrong?
