Wall sweeps
10 REPLIES 10
Message 1 of 11
540 Views, 10 Replies
Wall sweeps
I have tried 2 methods of generating a parapet cap:
1 - Creating a wall style with the sweep.
2 - Added a host sweep.
The problem is that using either method or a combination of both methods
doesn't always work. I still end up with some caps that don't miter
correctly even after editing. Sometimes, different intersections will miter
and others won't. Does anyone have any ideas? A newbie, I am probably
doing something wrong.
Thanks!
-Jawknee 99
10 REPLIES 10
Message 2 of 11
I have the same problem. I would also like to know how to edit a wall
profile, say for a stepped parapet wall and get a sweep around and over it
nicely mitered. I don't think it can be done in Revit yet my client wants
it. What do I do?
"Jawknee99" wrote in message
news:5084745@discussion.autodesk.com...
Thanks!
-Jawknee 99
Message 3 of 11
RevitIt
Can you post the file ?
Message 4 of 11
Modeling->Create->Walls->Solid Form->Solid Sweep Pick edges....
One of the tutorials covers this...
"Storm Petrel" wrote in message
news:5085460@discussion.autodesk.com...
it. What do I do?
Thanks!
-Jawknee 99
Message 5 of 11
For some reason it won't post. Probably too big but I stripped a bunch of
stuff out of it.
wrote in message news:5085502@discussion.autodesk.com...
Message 6 of 11
RevitIt
How big is it ?
Message 7 of 11
5 MEG, - I'll try again
wrote in message news:5085884@discussion.autodesk.com...
How big is it ?
Message 8 of 11
How big is it ?
Message 9 of 11
RevitIt
You can email it to me daniel.hurtubise@@lemaymichaud.com
Remove one @
Message 10 of 11
melarch
Use the Create-in-place tool on theModeling Design tab to sweep a profile along your wall. Also, to get Hosted sweeps to connect use the Join Geometry tool on the toolbars above the optio bar.
Mel Persin, AIA
Message 11 of 11
tim2rev
I have added a detailed trim sweep to a wall type and sometimes they do not blend together at corners. Any ideas of what I may be doing wrong?
Rail Community
