Wall Sweep to Follow Wall Profile
3 REPLIES 3
wkohn
3382 Views, 3 Replies
Hello All,
I was wondering if there is a way to get a wall sweep that's set up in the type/structure properties to follow a wall if that walls profile has changed.  For example, in the image below, I've split the wall and adjusted it's profile to create some cheesy angled parapet.  How do i get my wall cap to follow along?  I thought splitting it and changing it's height would work, but no.  And if I change the profile without splitting the wall the wall cap just runs right through the wall, as if the profiel was never even changed.  I have no idea how to do this and any help would be greatly appreciated.
~Wes~
3 REPLIES 3
ccollins
in reply to: wkohn
You can't use a built-in sweep on a Profile Edited wall.
You can use an in-place family, or a Roof by Extrusion as an alternative method.
You might also try using a Line-Based Family, with a loaded Profile.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
wkohn
in reply to: ccollins
Cliff,
Thanks for the quick response.  I was afraid that would be the answer.  I'll look into the other options you've posted and give them a try.
~Wes~
sgoodmansen
in reply to: wkohn
In-place families work really well for this situation.  I think The Revit Kid had a different method on his blog using reference planes, but in-place families are super easy.  Only advantage to his method was the sweep actually changed when the reference plane changed, but its a lot of work and I never got it to work successfully myself.
