Wall sweep, profile, line weight
4 REPLIES 4
1731 Views, 4 Replies
Hi, I have a wall sweep on an interior wall and the line weight is very thick in my interior elevation. Could anyone tell me how can I fix it?
I tried "visiblity/graphic overide">Walls>Wall Sweep-Cornice and override the projection line weight...it didn't work. Also tried changing line type in the wall sweep profile file but it doesn't allow me to change...
Thanks!
4 REPLIES 4
Scott_Womack
I assume you are referring to a wall sweep applied separately, and not a part of the wall style, Correct? I'm not aware of an easy fix, but you can use the linework tool in each view to lighten the linework up. The biggest complaint I hear when the sweep (horizontal) is a part of the wall style is that the lines are too light.
thanks!
Yes they are separated. (Modelling>host sweep>wall sweep)
I need to draw raceway on each lab. wall sweep seems to be a good tool coz the profile is the same everywhere and I can adjust length on plan and height on interior elevation.
Besides line weight, I would also like a hatch on the sweep showing on plan but not elevation. Any idea how to do do that? I tried material>surface pattern, it shows the hatch all around the wall sweep, and therefore showing on both plan/elevations. Wish there is a material ID system like they have in 3dmax.
gary
Any resolution to this thread?  Im having the same problem with a sweep in the wall style.  It is showing up as a heavy line in the elevation.  When i use the linework command to override in the elevation view it looses the breaks through other elements like mirrors, soap dispensers.
The sweep in question is the tile or frp 4' high on a bathroom wall.
Maybe there is a better way to illistrate?
Gary
paulGLDEG
Hi there.
I ran into the same issue with a custom wallsweep showing in heavy lineweight on my facades, regardless of the graphic override I applied. Even tho I could have edited it with the Linework tool, the profile I used was quite complexe and copied several time, and it would have took too much time to do manually.
To change that, I had to modify the Type Propreties of the family:
Edit Type > Identity Data > Subcategory of Walls : By default on Common Edge, switch to <None>.
That was enough to turn every sweep of the family into a regular lineweight. Hope that helps.
