My wall sweeps are not joining where one wall buts into another. Can I fix this, or should I use a stacked wall? Thanks.
Let me know whether you have made your wall sweep by using wall sweep tool or you have made it in wall assembly.
If you have made your wall sweep using wall sweep tool, then attach all the wall sweep segments one by one sequentially (don’t exit sweep commands until you place all segments).
Try to create wall sweep using wall sweep tool and then attach all the wall sweep segments one after another.
Just as a thought..
If you select the wall, the wall sweep grips should appear, you can drag these to the corner to ensure the two wall sweeps meet. The corner points for the sweeps need to meet for it to automatically mitre.
