Wall skins pattern
2 REPLIES 2
Phil T
337 Views, 2 Replies
Wall skins pattern
Hi, I am a newbie so go easy. I have searched high and low but cannot find how to nominate hatch patterns for walls in plan view when there is more than one skin. ie. brick / cavity / stud. i want say a brick hatch for the brick and a shade for the stud but don't want to draw separate elements on plan. Please help put me out of my misery.
2 REPLIES 2
in reply to: Phil T
Go to the element properties dialogue box of the wall and then go to edit, edit structure, and then select the material you want to show with a hatch pattern. Select the type hatch you want under cut pattern (i.e. diagonal up-small for brick), for each wall component you want to have a pattern for. Set your detail level to fine, and your different components should show different hatches. Phil T wrote: > Hi, I am a newbie so go easy. I have searched high and low but cannot find how to nominate hatch patterns for walls in plan view when there is more than one skin. ie. brick / cavity / stud. i want say a brick hatch for the brick and a shade for the stud but don't want to draw separate elements on plan. Please help put me out of my misery. > > Thanks
Phil T
in reply to: Phil T
thanks for that Henry. Worked fine.
